where are you located? I'm interested in the 12v alternator. Thank you.
Do you still have the power steering pump going to M8X 1W5 in OntarioSo I'm in the process of building a new rig and am stealing parts from a couple others lending those rigs to become parts donators.
I'm foggy on pricing but I'll try.
2h 12V starter (used but in good working order) $150
2H 12V alt. same as above. externally regulated $200
HZJ 77 parts. It was a roll over and doesn't have much left. I took the engine. Axles and suspension are gone. Good glass is gone, most of the little electric bit are still there like solenoids and stuff.
A440F from above with or without splitcase. Converter looks new on it, only going off shiny purple paint, and fluid was clean as a whistle and not burnt smelling. Looks to be a good runner. Has cooler lines and flex plate too. $500
HJ60 parts misc just ask.
HJ 47 engine and trans, Has the good H41 with low first that mates to a split case. 2H is a sleeved block that needs serious help. Runs and drives now but overheats and needs a rebuild. 400k on it according to odometer. I've driven it and power seems fine but compression was down as it is hard starting even with the glow working. No power steering or anything cool like that
HJ60 2H dissasembled. Plan was to polish and port this but bought an HZ instead. Head is not cracked and most of the work done. If there is interest I'd likey sell this engine whole or parted...
2H head.. Solid but needs rebuild. 400
2h Block with good cyclinders, needs rings and pistons, OBO
24V alt, Rebuilt within last 30k 300
24V starter, brand new motor and solenoid part but nose cone was reused, 300
AC bracket for 2H 100
PS pump and brackets and idler 400
All parts are OBO just let me know what you figure. Maybe my prices are out to lunch..
All parts are in Edmonton Alberta. Use T0A 1N6 as a postal code for shipping estimates. I can ship via most common carriers.
