I'm told that it's possible to change the valve stem oil seals without removing the head by using a special tool to remove the valve spring. Obviously one has to remove the rocker assembly first, and insert through the spark plug hole something to prevent the valve from sliding down (yeiks!) Then depress the valve spring, remove the keys, take the spring out, remove the oil seal and tap a new one in, etc.
Anyone done it? Anyone know what this tool is named and where to get it?
Thanks!
D
Thanks!
D
