I think this is a judgement call only you can make. FSM says do it. Mine were bone dry and very well secured by the cured FIPG, so I left them alone and have had no issues.
I've seen mixed opinions on that, did you do yours ? How did it hold up ?
Below is a pic of my valve cover leaking/oil mark. And based on how many issues I had here there so far I could see my LC has not been taking care of so much by its PO except polish it very well (maybe a little bit too much polish)~
1. So, I think, in my case re-seal should be a better bet than re-torquing, is this right? (maybe it been re-torqued a couple of times by its PO)
2. And How many half-moons there? Four? Will it possibly fall off (because it is round bottom) when we put the cover back?
Thanks for any suggestion.
View attachment 2580149View attachment 2580150
It appears you need to replace the valve cover gaskets, from the photo it doesn't appear the oil is leaking any higher than the VCG. They become brittle over time and lose their effectiveness for sealing, it's a common issue with age and mileage. You'll also need to replace the valve cover bolt grommet seals and the spark plug tube seals. And while you are at it, change the PCV grommet, it too will be brittle and it's a pain to remove without the VCG off the engine (pieces will break off and drop into the valvetrain otherwise) They will all be brittle.I’m dealing with engine oil leak on PS (see pic) on my 06 lx470 with 131k miles. Checked the oil level and no surprise it has dropped a bit. No other signs on the DS. I am assuming it needs VCG.
Side note: For the last two oil changes I’ve used mobil1 EP and both times noticed the oil smells burnt prematurely (after 1k). Does this have to do with the EP type as well? Or just a coincidence? No oil leak or oil level drop at the time.
I’ve also changed PCV 15k ago and spark plugs 5k ago.
Do I only need VCG? Any other possibilities I need to rule out?
That looks about right. They bottom out in the seat anyway.I just replaced the spark plug seals. I saw they just slightly tab on them from some video, but my seals did not seem to come in easily, so I use a 30mm socket to drive them in, did I drive them in too much?View attachment 2592128View attachment 2592129View attachment 2592130
I’ll post some pics in the morning.Toyota will also do the repairs and both options will be in similar price range, labor times are supposed to be based on flat rate.
That being said that seems steep, ask them for a breakdown of parts and labor cost and go from there.
In the meantime pop the hood and take some pictures of valve cover area so we can see how bad the leak is.
Ok thanks. Quick question, Does air intake system need to be removed to replace gaskets on PS?First step would be to clean and tighten to spec. If the leak goes away, problem solved.
The intake manifold stays on but you do need to remove the resonator and air intake assembly ( black plastic thing ). A few bolts which are easy to get at but be careful with the delicate vacuum hose connections and plastic pieces. You will need to disconnect fuel injector connections, coil connections , and I think there was another cable or two in the way, just be gentle.Ok thanks. Quick question, Does air intake system need to be removed to replace gaskets on PS?
