For Sale (VA) 65 FJ40 Crawler
37 x 12.50 x 15 Goodyear MTR - Original design. Plenty of tread still on them.
Single Beadlock rims
5 total on rims with one tire brand new. Also have a 6th tire with no rim, needs hole plugged.
Strong 2F engine with webber carb, DUI HEI distributor. De-smogged. Header.
H41 4speed transmission with granny 1st gear from Oz. Split shifters on transfer case. Also has a crawl box with extra low range. Disc parking brake on drive shaft.
Rear axle is a FJ60/62 Full floating axle from Oz with 4.10 gears and ARB air locker. Drum brakes.
Front axle is FJ40 with disc brakes, spacers at wheels to match width of rear. 4.10 gears with ARB air locker. I also was told it has upgrade chromoly inner axles and birfields from Longfield.
Saginaw power steering which works great.
Power brakes. Warn 8274 winch. U-bolt flip kit.
New Corbeau racing seats with 5 point harness (only have 3 points installed right now). Mounted on very nice tube bracket bolted to the floor with grade 8 hardware.
I am sure there is more, just have to check it out.
Front windshield is broken and windshield frame is tweaked. Front right fender got crunched, but has a new replacement in the box.
$8900 OBO
Located in Haymarket, Virginia
I did not build it. It came from CA. I think Man a Fre did most of the work on it. I bought it from the guy who bought it and had it shipped to Virginia. He flopped it a few years ago and pretty much parked it. He got into boats. I bought it to maybe part out, but decided to get it running properly and see what it can do. I have another rig, so I figured I would sell it. If I can't get it sold, I may part it out. I have not had it very long, just got it running with new seats properly mounted. I basically have to many rigs and have to clean up the yard.
I spoke to previous owner and was considering buying it. It was. 5500 or best offer. It most likely went for less than that!
It is up for parts.
Everything else up for grabs.
I may be willing to ship big items. Axles, Trans.
What do you want in suspension parts? (to Wileycoyote)
But for everything without tires and rims, winch and air tank. I would do $6800.
Anybody interested in these parts. I will sell everything. 8274-50 Warn winch in great working condition $1000. 37 MTRS on beadlocks $1000 (6 tires. 5 beadlocks). Lots of these parts will work on fj60.
How much for the h41/crawlbox/T-case lineup?
