l'm having a bad week, (l'm being extremely polite) now my ute is blowing black smoke & using oil, so l'll have to get the valve stem oil seals replaced sooner than expected.(hoping thats all it is) Meanwhile tonight the ute began dying going up hill dropped to 1st to climb a hill l can usually take in 2nd no problem, was okay on the flat but holding back & was fine going down hill..revved okay downhill but l'm having to butterfly the accelerator uphill/ slightly on the flat. l had a quick look at the pump & l wasn't able to shut the engine down using the shut off valve which seems to be stuck..?...have l over revved it (less than 3k) & its jammed ? Or a faulty diaphram (minds gone blank excuse the spelling) or worse case scenario, is there oil getting into the the chamber (rings ?) So l'm having to stall it to cut it off, as the EDIC/wiring is playing up (waiting for a new 1 to arrive before l send the faulty new unit back for diagnosis altho the tech guy said the C3 diode which failed is for accessories, so he's at a loss without checking it.) With the faulty EDIC in place it cuts out, it'll start but dies, the original EDIC starts it..but won't shut the engine down via the key...and just to top off today l discovered my front strut is leaking oil. If l can't use the ute l'm back to hiring a truck (4 days this week) & again for next week..... Any thoughts guys...
