Hello to all,
I'm a proud new owner of a 1980 FJ43, and I am new to this forum. I looked at many threads trying to find an answer to my problem, but no one seems to have ran into it.
My steering has some abnormal play/feeling to it. I could literally wobble it around. Felt like a loose upper bearing, which would already be uncommon... I decided to take things apart, and discovered that the ignition housing is the problem, it has worn out in the bottom, allowing the bearing to have some play.
What didn't help at all was that the retaining ring that's supposed to be on the column shaft was missing, and the retainer for the bearing on the column housing (Holding with three screws) is not the right part or shape at all, rather than hold down the bearing, it does nothing...
See the pictures for reference. Picture 1 shows the bearing in place, you can see the gap from the wear under it. Picture 2 has the bearing lowered, so the gap is now over it. Pictures 3 and 4 show the weird shape of the retainer, not being flat...
My questions are
1. What would you guys recommend? Easiest way is getting a replacement ignition housing, but mine being a locking column, I've been searching for one for months, but can't find one. Anyone here have one for sale by any chance??
2. I figured I could possibly fill the gap somehow, and was thinking that ''shim stock'' would be best. Any advice on that?
3. Anyone have the retainer for sale, or know where to find one? It's OEM part number 45269-36010
Any help would be appreciated. Thanks
My questions are
