Hi everyone
Unfortunately this happens when I’m on the road with family and not back at home, with tools etc or the local shop.
But today while driving the windscreen wash was working, then I noticed it barely come out, then stopped completely, the back windscreen wash then stopped working also.
It was 28f when it happened, and, as far as I know only Rain-X windscreen wash fluid was in the reservoir after the dealer.
The pump is making noise when I call for wash, but nothing comes out. I checked the lines and again I don’t have any tools with me cos I’m on a family road trip, but I believe the line runs on the driver side via a black tube and then turns 90 degrees under a plastic cover over the windscreen wash ejectors. My suspicion is a line disconnected in there somewhere but I’ve no idea what you call that part or even how to remove it to inspect the line
Can anyone help here?
Again, reservoir is full, topped it off with -25f fluid today after this issue happened and I believe it had rain-x windscreen fluid in there before. The motor is making noise when I pull the lever. But nothing comes out the ejectors.
I wiped the ejectors to make sure no ice or dirt blocking both of them, and rubbed it with a rag and pours the -25f liquid on top of them in case any issue. Used a paper clip on them to make sure nothing blocking.
Any suggestions?
And bear in mind I’m on the road but really need this resolved asap as it’s snowing and the worst time this could happen
Any suggestions?
