mattressking
10 digits to freedom
Another one bites the dustUpdate: Gray ones are NLA. I am an idiot and should have ordered these when I made the post. SMH. Lesson learned.
Jason at Trail Tailor is stocking a replacement. I haven't seen them in person but that would probably be your best option now days.Update: Gray ones are NLA. I am an idiot and should have ordered these when I made the post. SMH. Lesson learned.
SEM paint is a great match via Cruiser CorpsUpdate: Gray ones are NLA. I am an idiot and should have ordered these when I made the post. SMH. Lesson learned.
Much obliged for the insight, I'll order another way then. Thanks!It’s not dead. They just don’t want to get it for you.![]()
I just ordered an upper one. They told me the lower one is NLA. This is the better situation since you look at the top one, and the top one has the plastic holes the screws thread into from underneath, which are broken. Hopefully the grey is the same as the original 40 year old OEM bottom.Update: Gray ones are NLA. I am an idiot and should have ordered these when I made the post. SMH. Lesson learned.
Toyota Parts Direct in Canada. I haven't gotten it yet but he emailed me to cancel the lower one because it's NLA and said the upper one is still available. I'm guessing they have to order it in from Japan first.Where'd you find it?? Online parts sites in the US and abroad seem to say NLA, and that was also confirmed by a parts guy I called.
81560-90A12
Looks like the overseas LH rear taillamp assembly is still available.
No, I never ordered. The difference is that the overseas version does not have the side marker light harness off the tail lamp wiring. It could easily be added - just something that's not there currently. It only uses +12v and ground for parking lights so it's just a tap into two wires and resolved if you want a new taillight. You could even pull the wires off your existing taillight and swap it over to make it seamless.I'm working on ordering soon to be NLA stuff.. Did you get this? Is there any difference between this and the USA Version (like for DOT requirements)?
| Front turn assembly LH | 8152069165 |
| Front turn assembly RH | 8151069165 |
Front turn signals are the same up front as USA. The only difference that existed for J60 trucks were 24v vs 12v and that was just a bulb change. I bought overseas lamps new for mine and they are the same. Just pricey.I wonder if the same is true for the front turn signal assemblies.. Both seem to be available for non-US spec cruisers:
Front turn assembly LH 8152069165 Front turn assembly RH 8151069165
