ubolt flip
I'm working on my ubolt flips so far I have the GM Plates> GMPartsDirect.com. Part # is 15592588
The 5/8" u bolts I got bent at fleetpride for a really good price they bent them while I waited.
I have the steel I'm going to machine to locate the u bolts under the springs. The only thing I haven't figured out is what to do about my rear shock mounts on the axle. I like RuffStuffs mounts but am trying to find a cheaper way, am I just waisting time trying not to buy them.http://www.ruffstuffspecialties.com/catalog/axle-side-mount-shock-brackets-p-210.html
I don't want to weld a tab on the mounts like Man-A-Fre's because that's where mine are now and I already damaged one shock because they are to low.
For those that don't know these are for a SUA rig. Like Man-A-Fre's but cheaper. http://www.ruffstuffspecialties.com/catalog/axle-side-mount-shock-brackets-p-210.html
Trail gears won't work for what I want, I need them off the bottom of the tube.
I Machined the plates today that mount to the bottom of the springs unfortunately I messed one up and now only have three. I know better I should of got enough to make a mistake.
I put the rears on and used the stock shock mount on the axle and re drilled some 5/8" holes through the cross member to mount the uppers slightly farther in. I cant wait to scratch them.
Looks good! Must be nice to have "skills".
Lane
So how much do you think the cost of doing it yourself was?
You couldn't find the right size u-bolts?
Could you have made the plates welding pieces together
to give you the grooves?
Lane
Lane
While I can't speak for Mark; I can speak to this part of your post. I have found it is often cheaper to have the u-bolts made at a local spring shop than to buy an off the rack u-bolt in the same size. There are quite a few shops around Boston that can do this. I have used a place in Brighton in the past, Brighton Spring or Alston Spring IIRC. Got parts that fit at a price I was happy to pay.
Nick
Not a bad price, all 4 for less than you'd pay for one Manafre kit.
I've seen the write-ups here on Mud, and was always interested in trying it.
Take the day off and go trail test it.
We'll expect a write-up on it tonight!
Do you have the code for your cadd drawing on those plates? Looks mighty sweet and could be done by another CNC elsewhere?
Thanks!
When I needed them for my truck a few years ago I worked next door so I ran over on lunch thinking I was going to have to go back and pick them up but he had them bent up in a few mins. I think they were only $20 for the 4.
