I am looking at the 4 plus flipkit and I was just wondering if anyone knows how thick the bottom plate is. They say the top is 5/8 but no spec on the bottom. Thanks.
Ben
Ben
Is this the one that Man-A-Fre sells? Their bottom plates bend and require another plate to be welded on to reinforce it. Ask me how I know.
the bottom plate can't bend if it's on right, Theres nowhere for it to bend to. The 5/8" top plates were bending on the 60 front but that was recently changed. Unless you mean the shock pin. That can bend if you set down on it. It's a 5/8" pin
check the pic at this link, do you have the bottom on correctly? I've seen people put them on rotated 90 degrees
Man-A-Fre Advance Off-Road Solutions
Yep, they were installed correctly. Confirmed that one with MAF. All you gotta do to bend them is torque down your u-bolts. How did they change them? Must've been relatively recent, or possibly they gave me the previous flawed design when they tried to send me previously used parts with my OME order...wouldnt surprise me at all.
yeah, I can see the plate follow the gentle curve of the leaf pack but I don't know how they could bend down . The pack springpack is quite thick at the u-bolt and I would hope the spring never bends there. I would expect an eye to bend first
I read all about the bending issues and decided to stay away.
Maybe in the future i'll buy a set and "fix" them before installation.
That's what I would do. I love the kit, I used the parts when I did the SOA. I would go into it knowing that some welding should be done prior to flogging it, that's all, or fab my own...
