If I knew how to interpret it, I would check the wiring diagrams for VSC
What about disconnecting the Skid Control ECU, would that disable too much or is skid control essentially VSC?
You do not want to disconnect Skid Control ECU. The best you can do is disable VSC by either run CD locked or faking it to Skid ECU. If you disable ABS, the front / rear brake proportioning will not work and that is dangerous.
