Hi, I am new and I have had a look on a few threads related to this topic, but had a few specific questions to my situation.
I have a 2005 LN167 Hilux with the aforementioned 5L-E engine in it. The truck has done around 340k kms, and I have recently discovered that it had spat its thrust washers out and as a result, the crank was walking.
I did a very intermediate fix on it in which I replaced the washers and bearings. Before replacing the washers, the crank had about 60 thou of play, and now it has about 20, max factory is 12 I believe, although I could be wrong on that.
I am thinking it will need a new crank/machined crank and possibly the maincaps too, although I haven't had the time to investigate further, as it has been my daily up until recently.
Long story short, I am looking at doing a bottom end rebuild, and I was thinking of turboing it and pushing between 7 to 10 pounds of boost, as I am sure it is well known that these engines tend to leave more to be desired in the get up and go aspect. There is no smoking or signs of any top-end issues currently. I am wondering what the best approach is? Should I get the crank and main caps machined and use oversized washers and bearings, or get a new crank? In terms of a turbo I see that ct20s are a common turbo used, TD04s too as well as the turbo that came with the 2LT engine.
Would I need a new injector pump, potentially one with a boost compensator, or would the stock 5L-E one be fine but with an ECU tune?
In terms of mounting an intercooler, where is the best place to do that in these trucks?
What other things should I consider, based on the age etc?
