- Thread starter
- #21
Brian, any new information on whether the LC200 2016 caliper is compatible with the pre-2016 knuckles?
From the quote below in another thread, it doesn't sound promising. The updated 2016 Tundra calipers do not fit the pre-2016 Tundra knuckles. A critical detail would be the mounting bolt size increase. I'd assume the LC200 2016 caliper bolt size is increased as well. Just ordering a 2016 brake mounting bolt would be telling.
If I were to go down the pre-2016 Tundra caliper path, do you think by ordering a Tundra brake line, that I could retrofit the Tundra caliper to my LX570 without the caliper machining you spoke of?
Ok, just found out that the 2016 Tundra caliper WILL NOT fit pre 2016 Tundra as knuckle is different, mounting bolt size different as well, so it will not fit. Unless replace knuckle as well or possibly machine the mounting hole bigger to fit on pre-2016 Tundra or 200, not sure of the later though. So for sure 2016 Tundra caliper is not a simple bolt on as pre-2016 caliper. For that reason, it will not bolt on pre-2016 200 series cruiser as well.
The 2016 200 has different part number on the knuckle as well compare to pre-2016 cruiser, so it can be the very same case like 2016 Tundra unless proven otherwise. Will update if I find out about the 200 series parts.
