SOLD Tucson AZ: '77 2F engine
Tucson, AZ
Up for sale is my ‘77 Toyota 2F engine. It was swapped into my ‘69 FJ40 by a previous owner. Unfortunately it was ran with no oil pressure for a few miles unknowingly which is why it is currently taken apart. After the initial issue was addressed it did still run just with lower oil pressure. It is rebuildable however. I have the crankshaft and camshaft which can probably be salvaged. Head and valve cover also included. As pictured the cylinders have some slight surface rust but nothing crazy. This engine can definitely be rebuilt if desired. I don’t know if it will be of any use but I will include the pistons, oil pan, connecting rods, oil pump, and other miscellaneous parts that the shop gave me back. Let me know if you have any questions. $350 OBO local pickup from Tucson, AZ.
@POTATO LAUNCHER
Thank you for posting the casting number. It is compatible from the info I gathered however, I had a response from a buddy with the exact part much closer I was looking for. Good luck with the sale sir.
Casey..
Did your shop check the head and block for cracks? Was it ran hot? Let me know, I’m a couple hours away in las cruces. Thanks, Jesse
I don’t know if they checked for any cracks but they did say it was rebuildable. It wasn’t ran hot but it was ran without oil pressure for a few minutes. It was still running though when it got taken out of the truck.
