Ok, I'm finally trying to get my truck going(buildup in sig) and after relocating the fuel tank and letting it sit for over a year and a half without running, there are some problems.
We threw a new battery in it last night and it cranked just fine, but didn't fire. Pulled a plug wire and held it against the block, spark is good. So I go back and listen to the fuel pump, nada. Ok, I extended those wires, maybe I messed something up. So I started probing around with the volt meter. I pulled the main harness connector for the rear of the vehicle at the passenger side floor board and put the volt meter on the pins for the fuel pump. with just the ignition on, there was 0V, but when I had my friend try to start it, it cranked for a split second, and then the truck died, no power to anything. In that split second the volt meter read 3V, but then back to 0V obviously.
All the fuses look good, but I doubt it would be a fuse since everything is dead. Any idea what the problem is and why checking the voltage across the fuel pump wires would cause it? Thanks!
Ary
Ary
