hi guys just like to know what tool did you use to trun up the fuel on your 2H???
Nat
no special tool required. loosen the lock nut (12mm, I think), turn up fuel, tighten lock nut. about a 30 second procedure.
cheers,
J
oh ok i must be thinking about a diferant one
have you go at pic of the one your ment to turn up for more fuel??
did you have a pyro gauge .. ? higly recomended beforem start mesing with your fuel ..
other pic ..
The fuel adjuster is the screw that stops the edic-arm in the rear position..(the one in tapages pic. Impossible to see what you mean in the first pic.). There is a lever that says stop right? (wich you can pull to stop the engine) That is connected to the arm... and that arm stops on the adjustingscrew.. If you want more fuel you turn it outwards...so the arm stops closer to the fire-wall...
It has a circular lock-nut that can be loosened with a small hammer and driver, just stick the driver in a hole on the face and knock it loose..
To my knowledge this is the same on all 2H's .So if you don't recognice it you need to take another look.;p The other adjusting screws should be left alone...they only set max revs and stuff like that..
HJ owners i know usually don't mess with the fuel-screw unless they have added a turbo to their engine.. I don't think there will be a huge difference in performance.. but don't take MY word for it.
Edit: Oh i guess you have a turbo..
I have the HAC in my 2H .. so to clarify, turn the hole HAC outwards to get more fuel. But again .. I don't recomend that without a pyro gauge.
HAC ?
