Truck won't turn over
North of LA California
Took the truck offroading today and it performed flawlessly. Started up every time no problem. I get the truck home tonight and park it in the driveway. Come out later to go and it won't start! :mad:
When I turn the key nothing happens, the starter isn't getting juice. I checked the wire going straight into the starter because it has come loose in the past and given these exact symptoms. Still nothing. Checked my battery and basic connections. I pulled out my spare fusible link for s***s and giggles and that did nothing either.
Other than following the wiring start to finish is there anything I am missing. I was offroading pretty fast in a wash going maybe 20ish today if that helps at all. Didn't get near any debris.
Thoughts?
Have you checked your NSS? If everything's good and you get nothing that would be my first suspicion.
What is the NSS?
Neutral start switch on side of trany?
Your post on the NSS made me check and see if it was in park. It wasn't by a hair... Thanks for the little thing that helped. I feel stupid.
Guess I overthought that one...
Solved in 10 min flat. :)
