All,
I'm attempting to troubleshoot an issue with the AHC on my 2003 LX470 and just want to check and make sure my logic is sound. Recently, I noticed the front end seemed very high, as in nose up. The interior indicator shows "N" but the front is definitely higher and ride is uncomfortable/bouncy. If I try to select L or H, it seems to be intermittent on whether it will change, sometimes it just flashes and stays at N. Sorry, no Techstream but I assume a ride height sensor issue since interior indications are normal.
My question is on how best to troubleshoot which ride height sensor is bad - or if my logic is completely jacked somehow. When I disconnect the drivers side sensor and start the car, the front end lowers 2 inches or so and looks to be normal height. If i connect the drivers side back up, it raises back up very high (with interior still showing N). If i do the same with the passenger side, there is no change. This makes me think the drivers side ride height sensor is the issue. I removed it to take a look and it is very clean. I still cleaned it up and applied some dielectric grease to the connections but same issue.
2003 LX470
103,000 miles
Stock
Thanks for any assistance.
Ben
2003 LX470
103,000 miles
Stock
Ben
