Builds Triple eLocked 200 - Rainy Day Build
Eric Sarjeant
Ed Martin Toyota (Indianapolis)
Supporting Vendor
Noblesville, IN
Website
www.edmartintoyota.com
  • Triple Locked 2020 Land Cruiser 200-series.
  • Nitro 4:30 gears
  • Front and Rear Harrop eLockers
    Old Man Emu (OME) BP-51 Suspension with 2722 Rear springs and SPC Upper Control Arms
  • Bud Built Slider Steps with rock lights mounted under and wired to dome circuit
  • Bud Built Stage 4 aluminum skids (powder coated silver)
  • Bud Built stainless steel shock guards (powder coated black)
  • 12.5 gallon aux fuel tank by Long Range America (LRA) with upgraded fuel pump and fittings
  • 17" TRD Rock Warrior wheels with BFG KO2 LT285/70/17 tires
  • RedArc trailer brake controller
  • Factory Remote Start.
@Onur can you switch to a build thread please?
I like this. No, that’s not right. I love this.
Very nice
Freaking beauty!
The only thing I'd do differently is rock lights between the slider bars not on them. That way you won't rip the lights off.
Top notch work like usual :clap:
Great setup. I agree with the rock lights. Not sure they are in the best place for longevity.
I thought you could not install the OEM starter on a 2020?
You can! Just have to trick the starter to thinking it’s a 2017 model year in tech stream.
perfect stance!! love the conservative tire option... I am assuming no spacers?? if not, then I love it even more.
We used Spidertrax 1.25”
was the spacer needed for appearance or clearance to prevent a rub?? my understanding is the 285/70/17 fits on TRD RW wheels and is the factory recommendation?? so, will this wheel / tire combo work without a spacer??
also, on a related point -- will this wheel / tire combo work on stock suspension without a lift and with no spacers??
I had my RW on 285/70/17 no spacers on stock lift without issue until I got my lift. Full lock had little rub on the fender liner but nothing where you could drive with it.
Also will depend on which tires you get. BFG runs a little small compared to some other brands
