Malleus
Far west of Siegen
EDIT: The very first page of the repair manual says to use ATF or kerosene for cleaning (just goes to show you should read the manual). So alcohol is probably not on the list...
I'm overhauling a 2000 LX450 A343F. Since the transmission has only one forward gear, and had been steadily degrading from slipping in all forward gears to non functional when parked, I'm hoping all I see is bare clutch disks and worn steels. I know I'm going to see at least that.
Anyway, I don't want to put a clean, working transmission and torque converter back in the truck, knowing the system is contaminated, so I'm planning to flush the cooler lines from/to the transmission, before I reinstall it.
I'm interested to hear what and how others have done this, before I go reinventing the wheel. I was planning to use a drill driven pump at one open end of the circuit, flushing the circuit with cleaner/solvent and then ATF to run that out. I don't want to use ATF to clean the system; it's too expensive. I haven't decided what to use yet, but I'm leaning towards alcohol.
If anyone has experience with a better plan, I'd like to hear from you.
