Transmission and Engine question
just bought a 1988 fj62 272000 miles looks pristine no rust interior great only thing not working is auto door locks and ac but in shop :pnow to have ac repaired.
Question guy before me had tranny replaced with used but shifts kind of hard and leaks out of front little what am I looking at for repair or rebuild on tranny?
Question 2 engine runs good now but where in Jacksonville Florida area would be the best place to have it rebuilt right. And how much should it run for these 2 things to be done.
How long can these things go on 272000 miles is alot?????????
Welcome,find the cruiser club in your area,ask those guys.Better yet join that club ,go to a meeting one of them probably knows whats wrong with it!
If your transmission is shifting hard check / adjust the linkages. I believe it's the kickdown cable. I have not done this personally. The trany leak should be accessed and fixed.
Your engine should last forever, tune it up and keep feeding it oil. A short block is around $800 or cheaper if you get it from someone on here. Run it until it goes then throw in a used one with less mileage.
Start small, repair things one at a time and ask more specific questions.
expect around $2500 if the tranny dies and needs to be rebuilt
adjust the linkages carefully
flush it and run synthetic ATF... add an aux cooler.
cross your fingers.
a hard shift does not bother me personally
a slipping flaring shift or a refusal to shift is another story :(
an aux cooler should be considered a must on every FJ62 IMHO
If you are thinking of building the rig...big tires and stock gears are hard on an auto... a lot more load. a lot more heat. Make sure your gears and tires are appropriately matched.
Mark...
