Transfer seal
Website
www.humboldt.edu
Hey, I've got the leaking transfer/tranny seal problem with the oil getting pumped into the tranny and I'm tired of checking oil levels every week or so and I don't want to blow $60 on the quick fix oil return line. Do it once, Do it right. Could you tell me which of the part #s below is the proper seal? I believe it's #27. And--anything else I should consider replacing etc. when I remove the t-case?
Thanks,
:cheers: B
That looks like the seal.
There is usually a reason this seal is shot, do a rebuild kits in the tranny as it contains all new bearings. Plus address the transfer at the same time.
The reason that seal goes is usually failing bearings, dropping low on the seal and wearing it through.
Just by replacing the seal is a very short term solution.
there are a couple reasons that the seal goes. a seal can go because one of the output seals has leaked and the heat from no lubricaton has "burnt" the seal causing it to wear. it can be normal seal failure with age. i have never seen the imput bearing gone on a 2 piece t/case and i highly doubt that you have either Rob.
unless i see obvious signs of wear in the t/case internals OR extreme high milage or swaping a different set of gears in, i will not recommend that a customer throw away good money on a rebuild kit.
IF you suspect that the t/case has signs of wear or has been abused then buy the kit but you can just buy the 3 seals and the big gasket and be done with it. i can supply the generic part numbers for the 3 seals (if i can still find them), shouldn't cost you more than $60 Canadian.
BTW before putting the rear output flange washer and nut on put a bead of silicone jut over the spline are facing back and squash this with the washer. this will prevent the typical fluid leak along the splines.
Even if you rebuild the case it should only take you about 2-3 hours to complete the task.
HTHs
cheers
Well, the truck does have 400k kms on it, but there is no indication of a problem with the t-case. The PO was a gay surfer (I had never even met one in California!), not a wheeler, and I think he only used 4wd at the beach (judging from the sand I've blown out from the frame rails) or in the snow. The t-case shifts way smoother/goes into and out of 4wd way easier than the same in my FJ60.
Wayne, you mention 3 seals and "the big gasket." Do they appear on the above diagram? If so what are the #s there? This is a SOR.com diagram and it's easier to order from them since they are in Cali too.
Thanks,
B
toyota part #:
90311-48002 #24 front output seal,
90311-48003 #15 rear output seal,
90311-48012 #27 imput seal and the
36143-60020 #55 gasket...
cheers
Looks like my beast(89-BJ74) has developed the same problem,only thing is it filling up the transfer and draining the tranny,is it possible to remove the transfer case assembly as a one piece unit or does it have to be taken apart to reach some bolts inside the transfer case mounting the front case to the back of the tranny.
Just curious what does the quick fix set up look like and how does it work,I recall it might be a hose connecting the two,but how?Filler or maybe drain plugs..
Thanks James..
Thanks James..
It has to be split and the front half has to be removed from the transmission to get to the seal.
The kit is like this:
Dave
The quick fix replaces the fill plugs on both the tranny and transfer and connects them with a hose. I don't think it will work for your problem because the oil won't want to flow up hill to the tranny fill hole. But as Wayne notes above, this should only take half a day even for a noob like me, so why not take care of it once and for all and prevent more costly repairs down the road (especially in your case since it's your tranny that is getting starved). I am assuming that all that needs to be done is drain the oil out of both tranny and transfer, unbolt the drive shafts, unbolt the transfer, replace the seals, and then do the reverse. 2 bananas?
B
Maybe more than two bananas, B. Taking it apart is easy, putting back together is not :) The output shaft / gear cluster has to be kept in place making sure the high low shifter fork doesn't fall out while you put the back half on, be sure the thrust washers on the idler gear shaft stay in place, etc. It can be done, but don't do it at 11 p.m. the night before you go on a wheeling trip the next day (like I did).
Dave
Thanks (Dave)beanz2 for the pics,looks like a common hydraulic fittings, but I believe NorCalcruizr is right that mine is flowing in the wrong direction and the hose set up wont work in my case.I always get to do things the hard way.Oh well...
Thanks James....
Am I just a wuss or does my Aqualu tub make it impossible to get to the upper t-case bolts?
I was ready to tackle this and then I tried getting a wrench on all the bolts. The upper most bolts are impossible to reach--there is no room behind the t-case (body drops down right behind it) for a rachet and extension, and I can't get a wrench on them by going up the side.
You might have to drop the cross member and let the tranny down a bit. That'll make it easier to work on anyway.
I have long believed that a plugged t-case vent will also cause the weird low to high oil transfer. Make sure to put a proper vent in there while you are working on the t-case.
Wow. Can you lower the tranny-transfer by taking off the crossmember? Use a floorjack.
Dave
Its creapy that I'm agreeing with Wayne so much lately but I have to concur. In 15 years of destroying Land Cruisers I have never actually rebuilt a splitcase. I've pulled worn out parts and replaced them with less worn ones from my parts collection but never actually gone through and rebuilt the thing. I have, however had comments that my drivetrain sounds "like cats and snakes fighting" so take this post with a dash of salt.
Okay so I am a wuss. But I'll have to wait to get to my bro's and use his floorjack. This doesn't do anything weird to the engine mounts or anything???
On the diagram in the 1st post, can you locate the part # for the t-case vent? Thanks. --"breather plug" #6??? or "STC Breather" #59???
Sorry to jump in here again,just wondering what kind of vent-hose you replace the stock vent with,is it ok to replace it with a 90 degree fitting(pipe thread with barbed hose end) and run a hose to a higher point.
What is this STC breather,#59 for and will it cause fluid transfer.
Tried to do my tranny seal on the weekend but unfortunately I was given the wrong seal,the part # on the bag was right but it contained the wrong seal,knew I was in trouble when I opened the bag,so continued next weekend.
Just to be sure the 90311-48012 main seal should contain a spring on each side of the seal,yes?? like 2 regular wheel bearing or crank seals placed face to face,# side to # side.
NorCalCruzr there are a couple of o-rings that I found that might need to be replaced also,2 on the idler shaft and 1 on the tranny output shaft sitting just between the tranny shaft bearing and the gear the main seal runs on.I think if this o-ring or the one on the front of the idler shaft is worn or damaged it might also cause a leak,very slowly but one none the less..
Thanks James.....
