Yank the front drive shaft, lock the center diff and tell us how it does.
Are you still AWD?? If so why the manual hubs?
I'm not positive, but i think if you buy two new drive flanges, and maybe the cone washers and nuts that attach them, you can take the asian hubs off and just slide the new drive flange on, replace the c clip that holds the axle in place, and replace cone washers and nuts. I guess you'll also need 2 grease caps as well, those go on the drive flange over the axle end.I have to ask a couple of more questions to all of you cruiser' guru's.
First, what will it take to replace the AISIN hubs with the factory splines/axle end?
and also a little more diagnostic help. I took off the end of the aisin hubs and manually locked in the front axles, then put it back together. It drove fine. But the "clunking" is still there, and pretty bad. But I now know that it only "clunks" in HI gear on the transfer case. When I switch into LO, or push the center diff lock, the "clunking" stops. Would this have to do the front axles too? or is something elso out of whack?
Thanks again for all the help
Kent
Look at the front end rebuild FAQ, it has great pictures and you can see how the drive flange is attached instead of your manual hub.
I cant seem to find the front end faq with pictures, can you guide to the right area?
