When I got this cruiser there was a flood of T/C fluid coming out of the rear output shaft seal. Well, today I started to take stuff apart to replace it. On thing I noticed was that the output flange had a LOT of fore and aft movement and it moved up and down a lot. So much movement that the seal - which was stuck to the flange - could pe pulled away from the case with the nut still one. I hope that makes sense. All of this with the driveshaft off.
Took the nut off the shaft and I could move the shaft up and down and in and out. Pulled the bearing cover and the bearing was so toasted I could pull the cage off and all of the bearings just fell out.
Here they are:
The inner race is still on the shaft:
This is a dumb question but is it rebuild time for the transfer case?
Seems like it to me.
How hard of a job is this? I have the FSM and have looked at a lot of the threads on the forum. Seems like it is doable if you wake your time and think it through.
Any thoughts are welcome!
Here they are:
