Hello,
I recently purchased the transmission/transfer case oil return kit from SOR. The kit came with two aluminum type washers. The transfer case fill plug part would not tighten properly unless I used both washers. With a single washer it would tighten to a certain point then just "spin". It doesn't seem like I should have to put two washers there so I'm not sure what's wrong. Everything seemed okay for a few days but now it's leaking. What did I or what am I doing wrong on something that should be so simple to install?
Thanks,
Kevin
Thanks,
Kevin
