Trans question
Issaquah, WA
Could someone please give me the part number for the overflow plug on transmission pan? I have search and only find references to it not the actual part number. I went to a couple places online but only find part number for drain plug not overflow. Thanks
Search here too but only found mention not part number.
If you are talking about the plug on the side, the one you use to fill the transmission, it is the same as the drain plug.
The check level plug is different form those two, but the drain/fill plugs are the same.
The drain/fill plugs for the diffs and t-case are the same as the transmission, they're all the same. Same same.
I bought all new plugs from a place in Australia, switched from the Allen head plugs to actual hex head, it was cheaper to buy them from AU than to buy them here in the US, I do not remember the place I bought them from.
Thanks for the response. I am actually looking for the overflow plug. Not the drain plug or the fill plug. I believe it is a 5mm bolt though. I have the non dip stick transmission. It's a new to me vehicle with a fair amount of rust on it and I am slowing looking to replace bits and bolts as I go. Just can't find the part number for this particular plug.
