The other day I saw transmission fluid on the cross member under the trans cooler in front of the radiator. Has anyone had a problem before with their transmission cooler leaking? I searched with no results on a leak.
At least on mine the trans cooler is water:water and is integrated into the bottom of the radiator. The a/c condenser is in front. Is yours aftermarket?
Could just be the hose getting dry and brittle where it slips on. Are you sure it's not coolant? Both appear red. Smell to verify.
mine is stock it is in front of the A/c condenser.... it is leaking at the 90 degree elbow flowing in to the cooler ( i believe) its definatly ATF, it is red but does not dry out and leave red crusties. i already did the $3 fix( just in case) of the constant tension hose clamps failing and the rubber line..... but definatly not the clamps or line leaking.
Does it look like the tube stub or cooler is craked? If not could be simple hose job. Do check your trans fluid level if you think it's been leaking for a while.
