Tranny options
Can a mini truck t-case handle a V8 on 37" plus tires with me driving?
If it was me. Build a hybrid cruiser/mini truck axle (Woody had done this and there is info on mud) to get the centered out put or go the 9" route. Run an sm465/SM40 or auto of choice and a dana300. They are strong and you can get gearing for them reasonable priced. This allows you to step up to one ton axles if you choose to in the future without have to redo anything.
I was thinking about running a 12 bolt or an 8.8, I have a lot of cash & time into the front axle, plus I just got beadlocks so changing bolt pattern is out.
I have a 55" wide 9" with factory disc brakes and a 62"(about) wide 9" with parts for a disc brake conversion if you are interested
If you are going to put good axles in it, specify the bolt pattern you want
You can re-drill the axles shafts on the 9" and weld up the old holes or get aftermarket shafts which would be an upgrade.
OR
Build a hybrid cruiser/mini truck axle. http://www.ih8mud.com/tech/hybrid.php
Both of these options would get rid of C-clips in the cruiser axle which would be a benefit.
Tom if u wanna rear axle ill be pulling my mini truck out and replacing it with 9" this year. Its all build, with 4 link brackets
OR
I didn't think a 40 3rd would fit into a mini housing, OH nevermind <<<should have read the whole thang
So i'm leaning towards the auto, it's a 7004r, rebuilt with an adapter to a mini truck case, problem is the mini case is centered, anyone know if my 3 speed case will work with the adapter?
consider GM auto transmission to AA adapter to FJ60 split transfer case. Would that not work for you?
I've got a 60 with a 5.7 vortec and I'm using a marks adapter to get to the toyota 5 speed then to the fj60 TC. If I ever change or do another swap...The mark's setup will be out and I'll GM auto or maybe NV4500 manual.
I know with the 40 you only have so much room...some of the local guys run the old school GM 4speed manual with "granny" low first.
Probably like most I am on a tight budget so what ever deals I can find, that's what im going with:meh:
