My solution from the OEM 7 round to a 4 flat was to disassemble the OEM 7 round plug, (at the work bench) solder and seal each wire onto the appropriate wires for a 4 flat then out the back of the OEM plug and securing the new extension 4 flat behind the frame crossmember to and out the lower right corner of the receiver hitch area with enough slack wire to pull the 4 flat out and handle while plugged in and then pushed back flush when not in use. The OEM 7 round plug is still fully operational but at its original location. I did bend the bracket to tuck it up under the body or it would just get ripped off when off road.
If you ad an adapter that plugs into the 7 round to get the 4 flat you will still need to get/make a pig tail extension to reach the pivot point at the ball. Don't forget to secure it in a couple of places because if the plug falls out while driving it will destroy itself skipping of the ground at 70 mph.
Since I do not use the OEM 7 round, I would open the covering wash out any posable road salt, stuff a paper towel in the plug for a day or so to let dry and then hose the inside of the plug and contacts with LPS 3 to prevent corrosion and close the cover after you clean the seal.
