Thanks Henry, it is good to see some real world experiance.
I have a bunch of questions for you, hope you don't mind. Do you remember where you got that axle?
**I got the axle at a place called Arizona Trailer and Axle, it was somewhere south of GLendale, on the west side of 17th, close to the train tracks. I can try to dig up the receipt. I'm sure I have it somewhere...
Were brakes just not available, or did you just decide to pass on them? I have seen a bunch of trailer axles with brakes, but it seems like most were hydraulic or electric. You would think that cable actuated brakes would be easy enough to find, but I don't know if that is true if you need to go custom.
**I SHOULD have gotten electric brakes, but at the time the budget was low.
What size tires do you run on your trailer?
** 35x12.5R15's, same as on the Land Cruiser. Mounted on 15x8" steel wagons.
Does a longer tongue help with going forward--- highway and trail, or it just a reverse thing? The canadian trailers we have came with rotating pintles, that include a spring for shock abosrbing. I like the idea of getting a longer tongue, but I am not sure I want to give that up.
** Yes. I think the trailer is more stable, less squirrely. You might be able to keep the rotating pintles, I kept mine by extending the A-frame.
Now that I have asked you all these questions, I am thinking I remember asking you these things before.
I should probably check the archives before I ask anymore.
** No biggie, man, it's not like I don't like to talk about it!
Cheers!!!!!
H.
Jared
