- Thread starter
- #41
i have a 750watt inverter, and access to a 1300watt. that should be enough. i have to get it out of the box and see how much draw it has.
you will like that T-MAXX I have one on my 80 series and its the fastest winch on the market and the remote control actually works from a long ways away, did you get synthetic cable?
No, synthetic cable is down on the list for things in the future. Right now just the Aircraft cable it came with
After all of that you coulda just went with a powertank or onboard compressor or something no?
I may can get you a good deal on some synthetic line(its not T-MAXX but...)a friend of mine works at some kind of industrial job where he can get winch line and I know they use synthetic, ill let you know how much they would want for some synthetic cable, im getting some for our 40 series soon when we get a working winch
sounds like your gonna have oswald all ready for the Eglin run in Jan.
on Item #3 here is what I just picked up for my rig.
Newegg.com - MSI Wind U100-432US Black Intel Atom N270(1.60GHz) 10.0" WSVGA 1GB Memory 160GB HDD Netbook - Netbooks
then find a gps receiver I use one that came with MS Streets and Trips works great is USB but won't complain about that.
not to hi-jack but anymore coming over ?
X2 on the CO2.
Toyota of Dallas was running a deal on the Source onboard air, ARB deflator, and ARB tire repair kit.
EDIT: I couldn't find the original post in the classifieds, but they are running this special.
https://forum.ih8mud.com/**-ih8mud-com-vendor-marketplace-**/203598-source-co2-tanks-stock.html
I believe the threads are so close you won't need the adapter.
You are correct. with the brass an adapter is not needed, but i wanted to take the extra step, and it was only $4 more for the adapters.![]()
You will also need an 1/8" X 1-1/2" brass nipple and 1/8" brass coupling (a coupling with shoulders works best) for the rear diff. You can find it at a local hardware store. The brass nipple is needed since you will have to go through the rear brake line "Y". I used clear plastic tubing to run my lines and cable tied it to the frame, since cable ties can break away if needed. I didn't use an air filter, but I sell pheumatic fittings and have a check valve that I haven't tried yet.
I didn't need the adapters. The 1/8" brass thread easily threads into the breather holes. I also used thread sealant to seal the threads. Teflon tape should work fine too.
Where are you using the other 2? I know there is one breather on top of the transfer case...maybe the transmission too?
Buy 4 horsetail or barbed 1/8 -27 NPT brass fittings. (You could also use 1/8-28 BSPT fittings) These are available from McMaster-Carr or MSC Direct for cheap. 4 allow you to do both axles, the tranny (3sp) and the t-case.
It is on my list of thinks that Georg is setting off to the side, along with the knuckle rebuild kit for the disk conversion.Also, you need to invest in a transfer case saver to strengthen the top of the transfer case. The top of the case is the weakest point and they commonly crack from the top down. It's good insurance in preventing a cracked case. You can install it from under the truck, it's tight though.
Georg (orangeFJ45) sells them for around $40.
https://forum.ih8mud.com/merchandise-storefront/219733-t-case-savers-fj40-45-55-a.html
JoeTLC also sells them for about the same. That's where mine came from and fit perfectly.
Good Luck!
If i was really worried, i would tie the breathers into the snorkle...
werd said:Where are you using the other 2? I know there is one breather on top of the transfer case...maybe the transmission too?
Good point, had not though about that...I was thinking about doing this, but the snorkle is under a vacuum from the engine. It is sucking air through the snorkle, therefore it would essentially pull a vacuum on your axles. With the vacuum present in the axles water would be pulled in though the seals completely circumventing the purpose of the axle breathers. Just a thought.
Yeah, I should have checked the Breakdown diagram. .. but at least I have a spare should i muck up one while installing it.I believe the transmission is vented though the shift tower.
