What are you guys using these days?
HAM: I have a baofeng UV-5R (the stock antenna sucks, the batteries burn up and the accessory quality is iffy but it does okay for listening. I dont have a license either)
https://www.amazon.com/BaoFeng-UV-5R-Dual-Radio-Black/dp/B007H4VT7A/?tag=ihco-20
w/ two way speaker
https://www.amazon.com/Baofeng-BF-S112-Two-Radio-Speaker/dp/B008RZ0EQ0/?tag=ihco-20
and w/ battery eliminator
https://www.amazon.com/Original-Battery-Eliminator-Charger-BAOFENG/dp/B00DGW6ODG/?tag=ihco-20
hooked up to an antenna adapter
SMA Female to UHF
https://www.amazon.com/gp/product/B00COKNKS8/?tag=ihco-20
to a Browning cable
https://www.amazon.com/gp/product/B00BLCLUJ6/?tag=ihco-20
to a Comet flexible ant
Comet SS-460SBNMO DualBand 2M/70cm 144-148/440-450Mhz Ham Radio Antenna 18" NMO | eBay
mounted on a gamiviti fender mount
Antenna Brackets — Gamiviti
The stock antenna is the problem with transmission. There are upgraded antennas for the unit or better yet, external antennasI just bought the baufeng UV-5RHD
for whatever reason it can’t talk back but it can hear all other baufeng’s
Maybe because I ain’t got a license?!
It depends on what everyone you're talking to uses, but there isn't one radio that will communicate with CB, HAM and FRS/GMRS. The simplest and legal way is either CB (which sucks) or the FRS/GMRS radios (FRS is lower 2w channels; GMRS is 5w+; Just 22 channels combined for both you go to like a cb; see attached). You have to take a test to get a HAM license while you can just buy a GMRS license online to use the GMRS radios higher than the 2W limit. A lot of guys illegally use HAM radios without licenses, but I wont encourage that.@bamabrock are there any one and done solutions or do you have to have a different radio for each? That’s a lot to keep up with.
No, but in the past they were required. HAM and GMRS are also used and far better in the mountains. There was some talk of moving on from CB to GMRS last year. Midland did offer a 25% discount code for event attendees beforehand (they're really pushing GMRS).@bamabrock is CB the only option at HIH?
I’ve got an aftermarket antenna on my Baofeng and it works great, no complaints.Well, dang, I just bought an antenna for the baefung too.
About to give it all up.
FWIW the baefeng can work with FRS/GMRS
