Thanks for your reply Jetboy, sounds good ... what do you guys mean by a 'shackle' would this be a Jonny joint or the same mount as the ring end of a shock absorber - or something else ???
No, it needs a shackle, just like a spring shackle on the front to allow the foreward and aft movement of the axle. as the springs compress the rear axle should move rearward while under droop it will move slightly foreward. With your current set up it will just twist the axle a little. with a lader bar style it cant do that and will bind. Essentially what you have now is the same, it just looks different. The fixed "tower" you have on your axle will now be much longer and pointing foreward instead of up. The bar you have now acts as the shackle. The new trac bar is much longer which is why it works better. More leverage against the axle. The only forces you care about are up or down at the end of the trac bar. A shackle keeps that movement under control while allowing natural foreward to back movement. BTW the shackle needs to be verticle.
If you search for trac bar there are lots of pictures of them floating around.
