Toyota dyna 11b engine conversion in land rover. (1 Viewer)
South africa.Durban
Hi.Im doing a land rover build and i plan on using a toyota dyna 11b engine that i have.The gearbox i will be using is a lt95 box from a range rover classic.Has anyone here done a conversion like this i want to know the adapter plate thickness.
Hi.Im doing a land rover build and i plan on using a toyota dyna 11b engine that i have.The gearbox i will be using is a lt95 box from a range rover classic.Has anyone here done a conversion like this i want to know the adapter plate or would anyone know what cruiser gearbox would bolt to the 11b engine?
No clue. I would google search for spec's on both parts you want to fit and the ones they bolted into originally. There should be bolt patterns, spine spec's....
Check with Advanced Adapters they make all kinds of this stull.
X2 look into Advance Adapters
I’d also look into how the 11b bolt pattern compares to a 3B/13B. If they were the same… or very similar, it should make your search easier.
Toyota Landcruiser Transmissions to look into would be an H55, H41, or H42.
The only guy I know who ran a 3B in an old Rover used the entire 60 Series Landcruiser drivetrain. I believe he even used the 60 Series frame.
Not quite what you are working on… but I believe stock Landcruiser axles are stronger than Rover axles. Not that a small diesel engine would be stressing either of them beyond their limits.
