HI there,
I have a Toyota 81' model BJ40 Landcruiser, with a 3B diesel engine conversion taken from a Dyna truck.
No matter what I do this engine runs HOT. If I drive for more than 30 minutes from cold it will reach half way on the temp guage, and if there is heavy traffic with lots of idling it will get to 3/4's on the guage.
I have just installed a new sender unit and, had the radiator overhauled and had a fabricated shroud made up (as there wasn't a shroud when i bought it). But alas it is still running hot.
Is this normal for others out there with 3B diesels or as a friend who has a 13B engine told me it should be running between 1/4 and 1/2 not 1/2 to 3/4's?
Also I have noticed that when it gets hot (the 3/4 mark) and I turn the engine off - the oil pressure has dropped significantly and when I try and start the engine the engine cranks slowly and won't start. I am using a 15w-40 oil and live in the philippines where it is super hot here all the time. Should I be using a 20W-50 oil instead?
Thanks for any info/help anyone can provide
