This thread is making me feel better about towing my #2500 trailer all over the country next month. I second the AirLift 1000. I've towed with them twice now and its a night and day difference over stock springs.
Did you "T" the air lines or keep them separate for towing?
That was my understanding from the Airlift thread. T'd for articulation. Separate for towing. Thanks.Separate, no T.
@bctlex Sounds like either Uhaul doesn't know what they're talking about when it comes to the capabilities of our trucks, or they're trying to cover their a**es in the event something were to happen *knock on wood*. They just don't want to be held liable for any incident's that may occur that could possibly place them at fault (such as allowing someone to tow more weight than they should, when in reality you can with no problems). Horrible mpg? Yes. Can you do it though? Absolutely. Just turn overdrive off and take it easy. Watch coolant/oil temp & pressure and if you have a scanner of any type it'd be good to monitor trans temp too. Tell them you'll be towing something lighter like a '98 civic and see if they say yes.
Do you have an electric brake controller? It's not that the truck can't pull the weight, it's the stopping part. I had U-Haul install the e-brake controller for a little over $200. I was trailering only 3500 lbs and was definitely happy that I had it.I just got off the phone with Uhaul. They told me that my stock 98 LC do not weight enough to tow their auto-transport + Lexus SC430. Assuming I am buying the SC, I will be towing from TN to KY, about 5 hr this weekend.
Is this not doable? I thought LC should be able to tow this with no problem. Yes, I know I will have horrible mpg. Any advice?
