I have an 04 LC. It had a pretty drastic stinkbug stance, so I had the torsion bars cranked to level it out a bit (still some slant). I believe that all the mechanic did was crank the bars (and an alignment) and that he did NOT re-index the torsion bars.
My LC currently looks good (right stance) and drives well (on the street and fire roads, I don't drive it on anything harsher). I've also had subsequent alignments with no issues.
My questions are: What exactly does re-indexing the torsion bars do (I know it affects/increases down travel)? Should I get my torsion bars re-indexed and re-cranked (and an alignment) even though I'm not noticing any ride issues? Does re-indexing and cranking change the CV angles less than just cranking (i.e., would I be less likely to need a diff drop if I do both instead of crank only)?
Last, but not least, would you expect re-indexing and re-cranking to reduce some of the misc. noises that I sometimes experience and that seem to be coming from my front suspension (some pops and/or clank-type noises I get from time-to-time)?
Thanks in advance!!
Thanks in advance!!
