Tool Roll contents
Los Angeles
I swear, I've looked high and low for a list / photo of the Series 100 LC tool roll.
I apologize if it's just sitting out there and I can't find it.
I've found tons of lists, photos and threads for older LCs.
Mine is a 2004 Land Cruiser.
Thanks in advance.
Patrick
TOYOTA LANDCRUISER 100 SERIES TOOL KIT WITH BAG ORIGINAL EQUIPMENT NEW GENUINE
Mine is a 1998, but identical to the kit above. The two visible part numbers show up as part of the 200-series tool kit. Although the 200-series kits come in a hard case, I'm guessing the contents haven't changed much in the past 18 years, if not longer.
Mine is a 2002 and has the exact same items. I opted to loose the lug nut wrench and replace it with a breaker bar and socket which ride in the long upper compartment in the passenger side rear.
Good picture Labcab.
Great, great, great! Thanks guys!
With so many unused pockets in the roll, I was sure I was missing something - oh well.
I have everything shown above but replaced the metric wrenches with high-quality Craftsman single ones (box end and ratchet end for a total of four of them. Also replaced those cheapy pliers with a nice set that has rubberized handles. Same with the reversible screwdriver - one Phillips head and one slotted.
Additionally, I added one more extension to the jack extensions (I had it sitting around from my last LC), this way, I don't have to be on my back to use the jack.
Also, a couple clean mechanics rags.
All good. Now back to replacing / rebuilding my sub-woofer - why did the make every speaker in this LC have a custom bezel?!?
Thanks again guys,
Patrick
Thanks Labcab BUT, I'm so not into mods these days - I want plug and play for the most part. I'm working on taking the failed part of the OEM speaker appart, will buy fix it kit from Simply Speakers and move forward with my life
This is gold! Can anyone do my one better and tell me how the heck to roll this so my little cover/door over the jack stays closed?
It feels like I am trying to cram 10 lbs into a 5 lbs sack when I close the cover, and then it usually just pops off...
Mine fits in there, but my LC doesn't have the spare lowering key or any extra tools in the roll. It only fits in there at an angle and has a rubber/bungee retention strap that holds the roll in. Are you missing the strap, have a different jack, or have any extra tools in there?
