Tool Box Stuff
I learned about Cobalt and Tungsten bits after snapping off a 1/4 pipe on my compressor outlet followed by a snapped off EZ Out. Hours and $$$ later, I'm a believer in Tungsten bits. Now I only buy Cobalt bits for my general use bits, they rip through everything!
What size bit do you find the best to carry?
It’s a three piece set:
The knuckle studs are M12x1.5 correct? And hub studs M6x1.0?
Many people seriously under estimate the OEM jack. That thing is a beast and so much safer than a Hi-Lift when there's an option. With the Safe Jack adapter, it's really solid.
I have used my OEM jacks at work on construction sites many times to lift or horizontally shift things.
Almost without fail, guys look at me like I'm stoopid when I suggest the jack from my car, then amazement when it does the job
View attachment 2791647View attachment 2791648
Just bought a 3-piece set...I gambled a bit though...I bought the set that are Double End Drill & Reamer. I always need a good reamer and go through cheaper ones waaay too quickly. IF I encounter a broken stud (unlikely), I'll rely on Cobalt EZ Outs then use the Rescue Bit to drill out the EZ Out. :P
Found them.
Not cheap, but these sort of things can save a hell of a lot of four letter words being spilled
Note that @mudgudgeon actaully purchased the Left/Right Drill set. The Left Drill may act as an EZ Out. That link is for the double ended Right Drill set.
Can someone confirm the knuckle and hub stud spec’s.
I didn’t read this entire thread but I think it’s time to order a cordless angle grinder. I borrowed one during the Sierra Trek event last August to cut my rear sway bar off because one link broke and that end caught a rock and twisted back and into the ground like a plow.
Not a bad idea, that would take a while with a sawzall although you could cut the mounts fairly easily with the sawzall.
:steer::steer:
