Hi Mudders,
I'm new to Land Cruisers but not new to Toyotas and modifying them.
I purchased a 98 Land Cruiser earlier this year to haul more gear and be more comfortable on longer trips. Knowing how capable they are, my goal was to keep modifying to a minimum. I replaced the shocks almost immediately with Bilstein 4600s per recommendations from this forum.
Fully loaded on our first trip to Nova Scotia this summer it was evident that stock springs weren't up to the task. I decided on OME 865s because of their increased spring rate, low lift height, and the fact that they were much cheaper than new stock springs. Plus I'm familiar with OME since I had it on my 4Runner. My plan was to crank the torsion bars to get back to a 1" rake after installing the new springs.
This is where I ran into an issue.
The 865s gave me about a 1.5" lift as advertised. When I went to raise the front, I was limited to 515mm (center of hub to fender) with 60mm of droop. This leaves me with about a 2 to 2.5" rake. From what I have read it's unusual to be limited to this height as lots of people are lifting their front ends much higher. My only thought is that my shock is limiting my droop. Are these Bilstein's (part# BIL24-027397) known to be shorter than others? I know the rears are but I never read anything about the fronts.
Any help would be much appreciated. I'm thinking about just going to OME shocks but I don't want to pull the trigger until I know that I'm not going to run into the same issue.
