Hi all - I just changed out the suspension on my 91 FJ-70 from stock to OME, adding a couple of inches of lift (thanks for the tips from the forum on that topic). That allowed me to put on a new set of wheels and tires - Series 52 Rock Crawler 16X8 6-5.5 4.25 BS wheels, and ProComp 285/75R16 XTREME AT tires. I tried to order the wheels with 4in or less backspace, per comments on the forum, but all I could find from the dealer was 4.25in backspace so I decided to order and try it out.
Sure enough the rims in the front rubbed against the caliper, but a quick grind-down of .8cm or so from the edge of the caliper did the trick, and the front wheels fit fine otherwise.
But in the back I'm a bit worried about the fit. On the inside there is only about 1 centimeter between the tire and the bolt on one of the U-shackles around the leaf spring. And between the body of the vehicle and the wheel on the top-backside of the wheel, there is also very little space (maybe 2-3cm) between the wheel and the body of the vehicle.
I'm worried that when I get the truck onto some rough terrain, there will be enough flex in the system to push the tire into the bolt on the leaf spring and tear it open like a bag of chips. I have attached a picture here to point out the trouble spots, so just imagine between the yellow arrows that there is 1cm gap on the bottom and 2-3 on the top.
So my question is, first of all - is this a problem, and does the system 'flex' enough in moving over rough ground to push the wheel against the body or spring? And if the answer is that there is some risk, what's my next move? Should I come up with some spacers to put behind the wheels - and if so how much is safe to add?
Thanks! In all my reading on the forum I haven't seen exactly this concern come up with adding new wheels and tires.
Nuakameba
Nuakameba
