Tire Pressure for Rock Warriors with LT285/70/17, Load range Es? (3 Viewers)
10-4, got it. But there can be other factors involved in coming up with a recommended tire pressure. Would you happen to have the Load Limit Table for the LT265/70R16 E 121? The reason I ask is because that is the tire fitted to the 16" TRD wheel for the Tacoma, a BFG AT KO with same load rating as the BFG LT tires we are discussing. The Tacomas GVWR is only 5500 pounds, but Toyota recommends 46 PSI for that application also. Im guessing that tire at that PSI is going to give a load rating well above what the Tacoma requires. But they obviously came up with 46 for some reason. Maybe it has to do with some peculiarity of the TRD wheel/tire combo?
The LT265/70R16E 121 tires have a Load Limit of only 2,203 pounds @ 46psi where the LT285/70R17E 121 tires have a Load Limit of 2,559 pounds @ 46psi.
The only "obvious reason" for choosing 46psi appears to be some third-tier engineer in the U.S. distribution chain who decided, "TRD tires? Yup, 46psi. That's the ticket!"
HTH
HTH
Exactly, and whats the individual wheel load for the Tacoma? (By the way, that figure is not necessarily obtained by taking the stock tire and recommended PSI on door placard and working backwards.) Nevermind that. The only reason Im pressing this is because its a safety issue, and Im glad I did because I learned some new things.
Here's one thing, Toyota originally recommended 40 PSI for this tire/wheel combo on these vehicles and had stickers saying 40 PSI. Then, a few years ago, they adjusted that to 46 PSI, printed up new stickers, with a new part number. Considering all that happened between the time they originally started fitting these wheels/tires to these vehicles and the most recent recommendation, its hard to believe they wouldn't be sure about that new figure.
In addition, BFGoodrich themselves recommend 45 PSI front and 50 PSI rear for the LT285/70R17E BFG AT KO on the Toyota LC200. (
I called them, gave them all the pertinent info, they put me on hold for a while and came back with those numbers.) That applies to the KO2 as well.
(A related note, the TPMS is federally mandated to set off the light when the tire pressusre is 25% low. In the link to the NHTSA, HERE, about this particular recall/campaign, these tires, LCs, etc... it says that the TPMS warning light should be set to go off at 35 PSI. Doing the math you come up with a recommended pressure of 46.667 PSI.)
As a matter of fact, in the information that Ive seen, Load Range E tires aren't recommended to be run under 45 PSI, at highway speeds for extended periods of time, on any application, no matter what the individual wheel load is. It simply allows too much flex in the sidewalls and leads to premature tire degradation. The lower the air pressure, the more heat that builds up, speeding up the breakdown of the rubber.
I don't know, maybe some third-tier engineer originally came up with 40 PSI based on an elementary calculation that didnt take into account all the factors involved in coming up with the proper PSI recommendation for a tire and vehicle combination and then Toyota and BFG got involved and said "No, thats wrong."
I have no reason to believe anything other than running less than 45 PSI in these tires on this vehicle will simply lower gas mileage and cause premature wear to the tires, potentially resulting in catastrophic failure, as happened with the under-inflated Firestones on Ford SUVs years ago.
So, for the record, the BFG AT KO (and KO2), size LT285/70/R17 Load Range E, mounted on a stock 200 series Land Cruiser, is recommended to be run at 46 PSI by Toyota (after originally recommending 40) and 45 PSI front and 50 PSI rear by BFGoodrich.
Not trying to sound like a jerk, I just wanted to be clear about all this, because it is a safety issue and I fear there are a lot of people out there running around with under inflated tires. For what its worth, 46 PSI feels perfect on my truck.
Here's one thing, Toyota originally recommended 40 PSI for this tire/wheel combo on these vehicles and had stickers saying 40 PSI. Then, a few years ago, they adjusted that to 46 PSI, printed up new stickers, with a new part number. Considering all that happened between the time they originally started fitting these wheels/tires to these vehicles and the most recent recommendation, its hard to believe they wouldn't be sure about that new figure. [Can you provide any evidence that Toyota originally recommended 40psi F/R for the LT285/70-17 tires on the LC200?]
I called them, gave them all the pertinent info, they put me on hold for a while and came back with those numbers.) That applies to the KO2 as well. [Nowhere has Toyota ever recommended different tire pressures for the front and the rear on the LC200. This makes me question the validity of this recommendation from BFG.]
(A related note, the TPMS is federally mandated to set off the light when the tire pressusre is 25% low. In the link to the NHTSA, HERE, about this particular recall/campaign, these tires, LCs, etc... it says that the TPMS warning light should be set to go off at 35 PSI. Doing the math you come up with a recommended pressure of 46.667 PSI.) [The TPMS is reset by the user every time tire pressures are adjusted by the user. If one resets the TPMS to 40psi, then the warning will go off at 30psi. If one resets the TPMS to 33psi (stock tires), then the warning will go off at approx. 25psi. The TPMS warning threshold varies based on the pressure to which the user resets the system. Reading this comment you leave the impression that the TPMS must be permanently reset to trigger at 35psi - what then is one to do if one refits the stock wheels/tires for which the full psi is only 33psi?]
As a matter of fact, in the information that Ive seen, Load Range E tires aren't recommended to be run under 45 PSI, at highway speeds for extended periods of time, on any application, no matter what the individual wheel load is. It simply allows too much flex in the sidewalls and leads to premature tire degradation. The lower the air pressure, the more heat that builds up, speeding up the breakdown of the rubber. [The Tire and Rim Association ("The Tire and Rim Association, Inc. (TRA) is the standardizing body for the tire, rim, valve and allied parts industry for the United States. TRA was founded in 1903 and its primary purpose is to establish and promulgate interchangeability standards for tires, rims, valves and allied parts.") recommends tire pressures ranging from 35psi to 80psi for the LT285/70-17 Load Range E tires - based of course on appropriate Load Limit for the vehicle. This seems to contradict your assertions of, "... on any application, no matter what the individual wheel load is." Of course, you are correct, if tire pressures are set at a level below what is required for the vehicle in question, then heat buildup, tire flex, etc. become a real issue - but my contention is that (based on the science and personal experience) 40psi is a proper inflation for the LT285/70-17 tires and meets the same Load Limit requirements of 33psi in the OEM P285/60-18 tires. If 40psi is unsafe in the former case, then 33psi must also be unsafe in the latter - which, it obviously is not.]
I understand (and applaud) your dedication to avoid the promolgation of information you think could pose a potential safety hazard. And I don't want to be a jerk, either, but please see my comments in red in the quote of your post above.
Obviously, everyone is free to run whatever tire pressure(s) they feel comfortable with. I'm really not trying to "win" any point here - just providing the science behind the numbers and how the pressures recommended by Toyota appear to be driven by considerations other than science.
Good discussion.
HTH
When @gaijin speaks, all should heed his advice.
I go with our resident TOYODA, personally never heard of a recommendation of two differents tire pressure front and back for a permanent four wheels drive, with more psi on the wheels with the less load.
Good discussion.
HTH
Absolutely, Im just one of those people that has to get to the bottom of things. If Toyota and BFG are wrong about something like this, I want to know it. Considering that this would have happened after the Ford/Firestone fiasco and that Toyota has also had its fair share of recent recalls, I just find it hard to believe they got this wrong. I don't think the cost of those incidents to the manufacturers can even be calculated, certainly not the damage to their image.
To your questions,
1. This is the original Toyota document about the TRD wheels, stating 40 PSI for the tires and stating the original part number for the LC sticker. This is the Campaign/Recall documentation stating the old part number for the LC sticker and the new part number for the LC, which says 46 psi. Note section 6. This is what has me stumped. Why the change?
2. I think you first said Land Cruiser and not LC200 because I went and checked my TIP on the FJ62 and it is 29 front, 42 rear. I guess BFG is going by the differences in GAWR front to rear.
3. I was mistaken; was confusing registering new TPMS sensors, which has to be done with TEchstream, with initializing the system for new pressures, which is simply done with the reset button.
4. It is my contention that 33 Psi in the stock tire does NOT equal 40 Psi in the LT tire in our application, so that renders that point moot. It is my contention that there are other factors involved, i.e. wheel size, wheel width, spring rates of the tires themselves and its effect on overall suspension, etc... that are combined to produce the ideal PSI. The conversion calculation just provides a minimum pressure at which to start. But I could be wrong of course, I just want to know it and figure it all out.
One other tidbit I learned, as of the 2014 MY, Toyota does NOT put a recommended PSI on the TIP (Tire Info Placard) on the doorjamb on the LC! Just GVWR, GAWR and tire size. Whats the deal there?
To your questions,
OK! You have provided some very helpful links - which I actually followed, read and dug a little deeper - that have, I think, provided answers that we can both agree on.
Bear with me, I'll try to keep it short and to the point.
- The campaign/recall doc you cited explains that, basically, Toyota would be conducting a voluntary non-compliance action because the TPMS system, as then currently installed, would not trigger in compliance with Federal Motor Vehicle Safety Standard No.138 (find it here: TPMS FMVSS No. 138, Introduction )
- In FVMSS No. 138 it states that the minimum trigger pressure for LT Load Range E tires must be >35psi. This would require a recommended cold tire inflation pressure of 46psi in order to meet the 25% part of the same regulation. Here is the pertinent excerpt from that regulation:
  • The rationales for the minimum activation pressure are:
    A 20 psi floor for p-metric tires is required because the agency believes that below that level, safety in terms of vehicle handling, stability performance, and tire failure is an issue. The agency ran a variety of p-metric tires in what it calls a "low pressure endurance test" at 20 psi with a 100 percent load at 75 mph for 90 minutes on a dynamometer. None of these tires failed. In a second set of test it calls a "low pressure high speed test" at 20 psi with a 67 percent load for 90 minutes, in 30 minutes steps at 140, 150, and 160 km/h (87, 93, and 99 mph), about 30 percent of the tires failed. Since tires could pass the "low pressure high speed test" at 20 psi, this leads the agency to believe that there will be a safety margin, in terms of tire failures, if a TPMS warning is provided at or above 20 psi, that will allow consumers to fill their tires back up before the tire fails, unless the vehicle is driven at very high speeds (above 140 km/h or 87 mph).
    The lowest inflation pressure used in the 2000 Tire & Rim Association Yearbook is 140 kPa (20 psi) for P-metric tires. In the 2001 Tire & Rim Association Yearbook, the 140-kPa pressures have been deleted, apparently because the Association believes they are too low for P-metric tires. The agency agrees that 140 kPa is too low and believes a floor is needed to assure that drivers are warned when tire pressure gets to or below that level. For the LT tires, we used the 2000 JATMA yearbook for the lower limits for Load Range C, D, and E tires. For most cases, the floor is about 58 percent of the maximum inflation pressure.
- So, basically, here's what apparently happened:
1. Toyota originally recommended the correct inflation pressure of 40psi for the LT285/70-17 tires.
2. Toyota became aware that when the TPMS system triggered at 30psi (40psi - 25%) for those tires, it was below the threshold stipulated by FVMSS no.138.
3. In order to avoid being found in non-compliance with a Federal Motor Vehicle Safety Standard, Toyota raised the recommended inflation pressure for the LT285/70-17 tires from 40psi to 46psi so the TPMS would trigger at 35psi (46 - 25%) and be in compliance.
What does this action by Toyota leave us with?
- A TPMS system that is in compliance with FMVSS No.138.
- A recommended tire inflation pressure that is 6psi higher than Toyota would otherwise recommend.
Miscellaneous observations/conclusions:
- I have been using information from the 2014 Tire & Rim Association Yearbook which is, apparently, 14 years more recent than the 2000 Tire & Rim Association Yearbook cited in the federal regulation.
- The threshold low pressure of 35psi for Load Range E LT tires seems rather broad and arbitrary. This has been chosen to cover the worst case scenario of the TPMS triggering at 58% of Max Load which is far more than any of us with our LC200's will ever approach.
- I don't have TPMS sensors in my RW wheels, so all this TPMS talk is outside of my use case. This means that even if Toyota is forced to recommend a tire pressure 6psi higher than they would prefer just to comply with a TPMS federal regulation, I do not have to follow it to be safe.
Now to directly address your points:
1. Very helpful reference information. I think I have provided my take on, "Why the change."
2. Since we are in the 200 Forum, my statement was originally and still is for "LC200." I don't know what BFG was going by, but Toyota still recommends 33psi Front/Rear for the OEM P285/60-18 tires despite the different GAWR's of 3595LB Front / 4300LB Rear.
3. Hey, we all make mistakes.;)
4. I think that I have established that 33psi for the OEM P285/60-18 tires is equivalent to 40psi for the LT285/70-17 tires in our application. Toyota changed the recommended pressure from 40psi to 46psi in order to be in compliance with a threshold trigger pressure for ALL LT tires in general - nothing specific to our application.
Unless the law has changed (see it here: Tire Safety Information, Final Rule. ) there has to be a label somewhere showing recommended tire pressures:
    • 3. Vehicle Labeling
    Labeling requirements are also contained in 49 CFR part 567, Certification, 49 CFR part 575, Consumer Information Regulations, FMVSS No. 110, Tire Selection and Rims, applicable to passenger cars and to non-pneumatic spare tire assemblies for use on passenger cars, and FMVSS No. 120, Tire Selection and Rims for Motor Vehicles Other Than Passenger Cars.�
    Section 567.4 requires vehicle manufacturers to affix to each vehicle a label bearing, among other things, the Gross Vehicle Weight Rating (GVWR), which must not be less than the sum of the unloaded vehicle weight, rated cargo load, and 150 pounds times the vehicles rated seating capacity; and the Gross Axle Weight Rating (GAWR), which is the value specified by the manufacturer as the load carrying capacity of a single axle system.
    Paragraph S4.3 of FMVSS No. 110 requires manufacturers to affix a placard to each passenger car's glove compartment door or an equally accessible location showing the vehicle's capacity weight, designated seating capacity, the manufacturer's recommended cold tire inflation pressure for maximum loaded vehicle weight, the manufacturer's recommended tire size designation, and, for a vehicle equipped with a non-pneumatic spare tire assembly, the non-pneumatic identification code required by FMVSS No. 129, New Non-Pneumatic Tires for Passenger Cars.�The required information is intended to promote the vehicle's safe performance by preventing the overloading of the tires or the vehicle itself.
    FMVSS No. 120 requires that each vehicle show, on the label required by 567.4, or on a tire information label (S5.3.2(b)), the recommended tire size designation appropriate for the GAWR, the size and type designation of rims appropriate for those tires, and the recommended cold inflation pressure for those tires such that the sum of the load ratings of the tires on each axle (when the tires load carrying capacity at the specified pressure is reduced by dividing 1.10, in the case of a tire subject to FMVSS No. 109, i.e., a passenger car tire) is appropriate for the GAWR.
Final thoughts:
It's always good to find out why things are the way they are. As an engineer, I tend toward the scientific approach; but it is clear that when dealing with motor vehicles, there are always regulatory and marketing considerations that can potentially muddy the waters.
I'm still very confident in recommending 40psi for the LT285/70-17 tires, but fully expect others to make their own decision based on the facts as best they can determine them, and whatever makes them comfortable - no harm, no foul.
HTH
Aha! Well I think that explains it. So Toyota isnt exactly wrong, they are just practicing CYA policy! I should have known it was the good old federal government getting involved in something that fouled it all up. Thank you for figuring that out for us (or me)! This does mean though that BFGoodrich is, in fact, wrong. They would have no reason to abide by these TPMS regulations but they still recommend 45/50. Thats pretty weak that the tire manufacturer themselves cant even be trusted to recommend the right PSI for their own tire!
New question, what do you do with your TPMS system when you have the RWs on since they have no sensors? Just stare at the warning light and message that takes up the info screen? (That really annoys me and I want to disable the TPMS entirely.)
(On the stickers, apparently they are making separate stickers with the PSI on them, but they conspicuously have removed that info from the TIP.)
Very good information in this thread. Would the recommended tire pressure for a Nitto Trail Grappler (E rated) size 285/75/17 be the same 40psi recommendation as well? Thanks in advance.
I just ignore the warning light - there is no message, no blinking (after the first couple of minutes) and no annoying buzzer or chime. It doesn't bother me at all, but I would certainly disable it if I could.
HTH
No, the recommendation would be 37psi for those LT285/75-17 Load Range E tires on a LC200. Of course, that is not a size recommended by Toyota, so whether it fits or not is entirely on you.
HTH
Thank you sir
HTH
Ok, on the 08, the light blinks then stays lit and the message Check Tire Pressure System comes up when it can't find the sensors. They've disabled them on the Tundras by grounding a wire, Im just trying to figure out if its the same wire as the LC, studying the EWD....
I hear you can put all of the TPMS sensors in a pressurized pipe and leave it in the car somewhere, which will trick the computer into thinking the pressures are good, thus turning the light off. Never tried it myself, but that was a workaround mentioned in other forums in the past.
And thanks to you for digging and finding the key citations that ultimately led to a more complete understanding of the question at hand.
:cheers:
Great work on this to both of you! So I wasted a $1 on the updated sticker! It just came in.- as it was just a CYA move by Toyota. I can tell you that I went to 46 PSI on the BFG KO2 34x10.5x17 earlier this week and under driving it went up to 49 and I could feel the "looseness" of the ride. Felt like I was on skates compares to 35 I used to run. Did not feel solid.
So I am going To 40 based on this info. But please let me know if it should be something other than 40 for the RW and these tires with pretty loaded 200 series.
"The Book" says you should be at 41psi for a stock LC200 with the 34x10.50R17LT tires - that gives you 2,307 pounds of Load Limit per tire which is slightly above the 2,286 pounds recommended by Toyota. Bumping that up to 45psi would afford you an additional 148 pounds per tire or 592 pounds total for the rig. So, depending on what you mean by "pretty loaded," you may need some addtional psi over stock.
But remember, increasing the Load Limit of the tires does not increase the GVWR or GAWR's of the truck, so the more goodies you have, the less cargo you can carry - but that's a whole 'nother story.
HTH
Ok got it. It's fully rigged with drawers, fridge bumpers, Sliders, Rack- etc so looks like 45 it is. Have close to 500 pounds - even with rear seat delete.
:cheers:
:cheers:
Yeah I heard about that method, kind of chuckled, thought maybe it was a joke, but sure enough I then found pics somewhere where someone actually did it! And it does work, but id rather figure out how to disable it.
