I've been really happy with the Toyo AT3's. I ran BFG K02's for 60k miles and they were good but the AT3's are better in the snow, which was my main focus.
One thing to note about LT type tires is they hold up better to airing down than standard load tires. Slow rock crawling is not the issue. It’s when you’re traveling 25 to maybe even 50 miles an hour on washboard type roads when you’re aired down. The damage to the standard load tires is almost invisible, and can lead to eventual sidewall failure. LT tires don’t seem to suffer from the airing down stress to the side walls. Those of us that are experienced like to air down when going off road, for various reasons. So it’s best to be aware of this when choosing tires to run. I got this little tidbit from @LandCruiserPhil when we were talking about tires on a run back into the Maze in Utah several years ago.To be clear, there are two different LTX MS tire types, one is SL (Standard Load) which is what I run, and the other is the LT (light truck). Outwardly they look essentially the same but the construction internally is different, the LT variant could have a much stiffer ride in a stock 80 Series.
I guess the comparable Nitto to the Toyo AT3 would be the Terra Grappler G3? Do you have experience with those?
Note: Tires are defiantly a preference thing and you will get people praising a brand and then right after someone that would never run them.
