- Joined
- Feb 25, 2002
- Threads
- 71
- Messages
- 700
I've got a timing chain quetion for you 22R/E guys. I have a '88 2wd with a 22R while changing the timing chain,when I installed the new sprockets with the #1 cylinder at TDC the woodruff keys are pointing at each other. So with this the dots on the sprockets do not line up with the bright links at the same time. The old setup was the exact same way, so is this right or is something out ? I've turned the engine over with a rachet with nothing hitting just wanted to know if I need to check anything before finishing it up.
Hope this makes sense TAT,
Burl
Burl
(self duh
) Just wanted to thank everyone for their help ended up being I was at TDC on #4 instead of #1
. I did find out what was causing all the noise at start up the connecting rods are a little loose on the crank but what can I expect with 326,000 +
