So I am still trying to figure out why I am getting 4 point piston failure. The engine just got rebuilt a second time and when driving the rig under a load it had 4 point piston failure in two of the pistons, but I didnt drive it as long.
We have since pulled the engine thinking the mashinist had not bored it out to the proper tolerance. After taking apart the engine again we discovered that it was within toyotas tolerance. The pistons he used were also recommened by the toyota dealership. we are a bit baffled, the thinking now is that the fuel or the timing is causing the engine to run too lean and that is what is causing this issue. The first time we had the engine fail, we replaced the Mass airflow sensor. and had the fuel injection rebuilt. we are currently testing the fuel injection system to see if that could have been the problem.
My question is, is there a computer related issue that could be advancing the timing when it is under a load?
is there a way of testing the computer system or has anyone ever heard of this before?
Any input would be helpful.
thanks,
tren
thanks,
tren
