so the cheep mods continue....
This morning i tighted up the ole t-bars to gain a bit of lift in the front. I turned them 3 revolutions on each side and then measured
passenger side from center of hub to the bottom of the fender (i used the nut on the underside middle of the fender as a anchor point) = 20 1/4 inches
Driverside = 19 3/4 inches
I cranked the driverside one more revolution and bingo bango bongo....20 1/4 inches
Here is my question - i just changed my tires but on the old tires the driverside front was getting very worn on the outer/left side of the tire. I had the tire place do a realignment thinking it was out of whack. When he told me it was pretty much tru i became quite confused. So i am now thinking that since my driverside was sagging more than my passenger side this contribute to tire wear.......wadda think...
for the record - it was very easy to adjust......................and while i was under there i took off my running boards!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
looks a whole lot better...
