I have, what I think are bad exhaust manifolds. I get ticking under load (moreso on the passenger side) between 2K-3.5K, and suspect the manifolds are either cracked or the gaskets need to be replaced. To that end, I'm looking at options... As far as I know, I could do the following:
Thanks everyone. Sorry for the litany of questions.
- Pull things apart and fix the problem. That would mean welding what's there, or just replacing gaskets. Guess thing this somewhat costly at a shop for just labor, but no crazy parts costs.
- Pull things apart and replace -- OEM or DT. Much more costly, but a "permanent" fix. DT is more cost effective, but I've read there are moderate fitment issues (see questions below).
- Cover up the ticking and add a CB exhaust that growls a bit more. No, this is not fixing the problem, but it does sort of fix the problem as far as my ear is concerned.
Cheaper, pretty much bolt on. Has anyone done this?
- How bad will this install be? I've read 8 hours, and that the driver's side will be bad, but should I also be worried about broken bolts/studs? The truck came from GA, but was shared sporadically in MN until I got it last fall. For a 2007, it's in better than average shape for surface rust on the undercarriage. I have 149K on the clock. I'll be bringing it into a shop instead of attempting myself, but want to know how much downside there might be when the bill comes due.
- Should I get the long or the short headers? I have the Hewitt kit installed to bypass the AI, and I've read varying accounts for how to treat it/if it works to simply use the blocker plates. Any sage advice would be helpful here. I'm looking for an easier install, but also a proper one.
- Will the DT headers bolt into the OEM exhaust parts? I don't want to replace the CB yet (still a lot of life in the OEM stuff), but want things to fit together right. What parts do I need from DT to make this work right? I also want to future-proof it so I can easily install a CB when the time comes, which it will.
