Well I'll be a monkey's uncle. All I did was jack up the front to check wheel/trunnion bearing play, they were good. Greased u-joints, which I do about every ~7K miles and the thump is gone. Ujoints have ~20K miles on them, Toyota brand. Can't believe they were that dry that fast. I can still make it do it at juuuuuuuuust the right RPM's but if you know what you're doing you can pretty much get any vehicle to do it at just the right time.
Could you explain further? I never felt the 'need' to grease the joints, I just do it. They've never been dry, as in old grease is always pushed out when I grease them. I have zero vibes.If you are going through U-joint grease that fast I would tend to think your driveline/s are out of phase some
Just realized the thump that happens taking off from a dead stop goes away when it rains ie. when undercarriage is wet, but the higher speed thump is still there. Is that a tell-tale sign it's control arm bushings?
