- Thread starter
- #21
Maybe I have a DGES..... I could have sworn it said DGAS on it, but it's an electric choke. It's halfway across the world from me now, or I'd go check now. haha
Fj40jim is right. You can do a water choke or electric on the 38. It is not a progressive carb. They are easy to tune because they use the same jets side to side. If you are having a issue with throttle stumble off idle try getting some different emulsion tubes. Mine had f40's when I got it and now it has f60's it makes a huge difference especialty when getting on it on the highway or a hill climb. As far as air filters I have a adaptor that lets me use my stock fj60 air cleaner assembly. They also make a snorkel top that just bolts on to the top of your carb. The reason why I had asked about your air cleaner is the small open filter they send with the carb actually chokes your motor. Pierce maniflods is the main us importer for weber. They sell all of the kits and air filter adaptors you would need. If you need any help or part numbers let me know. Do you have the stock or electric fuel pump?
Ben
