Just finished replacing the PHH, thermostat and doing the annual coolant flush. One thing I was kind of puzzled by... after doing the coolant flush and drain, I installed the thermostat. I then filled the radiator up, but it only took about a gallon and a half of new coolant (and knowing that it took close to three and a half gallons last time. I figured, I'll start her up and get everything circulating, then see if the rest would go. I shut her back down after a minute or two and checked again. No dice. The radiator was still full, in fact some came back out after I open the cap again. Now I was getting a little worried. Everything was pretty straight forward... what could I have F-up?? So I cleaned up the tools, then moved the rig out of the driveway and into the garage. Next move was to write this thread to figure out what was going on. Figure I'd check one more time... then she was low. Put the other two gallons in, and stopped hyper-ventilating.
So what's up. Had the thermostat just not opened up yet??
Thanks,
Rookie2
Thanks,
Rookie2
